What did you do to it? Which wires did you move or connect?
The firewall resistor bank is a voltage divider network to drop battery voltage to around 12 volts when the glow plug solenoid is engaged. In doing so, it heats up, approximately the same heat energy is dissipated in the resistors as in the glow plugs, it will get hot. If the prior owner pimped the engine bay with Armor All, WD40 or any other product to hide dust, this substance will cause smoke.
You will need to download the technical manuals and make sure the wiring follows the diagrams.
Solenoid tests open on ohms with key off...Probably the solenoid welded itself shut. Could be the control card if the output transistor failed short.
The solenoid main lugs should have 24 volts measured at the top or resistor side with key on, engine off. The lug with three orange wires (2 large, one small) should be 0 volts except with glow plug system on.
There are two smaller lugs, one is switched 12 volts, the other goes to the control card since NPN transistors are ground sources when triggered. I forget those colors..
I'm starting to suspect the cardProbably the solenoid welded itself shut. Could be the control card if the output transistor failed short.
I'm starting to suspect the controller card...Probably the solenoid welded itself shut. Could be the control card if the output transistor failed short.
OkSaint, Please write your State in the location block, IAW the forum rules.
Thanx KeithThe controller card will show heat damage to the output transistor if bad. Pull it and examine. Improved version can be bought at Hillbilly Wizard, pricey but well designed.
I think I got it now, I had the city listed as the location, changed it to the StateOk
It says it has to be added to my profile, IDK how to get to my profile?
YeaThe controller card will show heat damage to the output transistor if bad. Pull it and examine. Improved version can be bought at Hillbilly Wizard, pricey but well designed.
That is the output diode, not transistor. The transistor is the black block with three wires and the screw on the heat sink. It could be fixed but anyone with the skills would charge $180 plus postage.Yea
It's cooked,know where I can get another one that dosent cost a arm and a leg...
