M1028 top speed
junker46
Pensacola FL
I finally got my '28 titled and on the road. I let a friend dive it and was amazed that the top speed is about 50 MPH without over-revving the engine. I drove a '28A3 about 7 months ago and noticed it shifted -very quickly- and top speed again was about the same as my plane jane '28.
He want to know if it's governed or something else that limits it. I think its just geared that way. And, what could be done to bring-up the top end cheaplly (he's considering buying it).
Also, whats is a good license plate holder to use on one of these? I'd like to leave the pintle hook in place and put a holder on the tailgate, but FLA wants the plate to be in position as production model.
dstang97
30
Clover, SC
55 top speed with the gears. put on some 37's and get 65 mph. or re-gear. I mounted my plate on my tailgate and have not been pulled over yet.
63B40
Johnson Valley, CA
You might also look into a gear vendor overdrive. They have adaptors fot the NP205 and 208 t cases and you would still be able to keep the 4.56 ratio you have now. They are pretty much bullet proof and can be had for around $1000-1500 used.
junker46
Pensacola FL
I have thought of that. Any idea what part numbers?
junker46
Pensacola FL
You could also swap out trans with an overdrive unit.
I've thought of that but wonder what all the requirements would be: donor vehicle etc. Anyone ever done it?
I also wonder what the cost difference would be between the two (700R4 or GV overdrive) or justifiable try to add an OD. Then like someone mentioned a lift and taller tires.
I do like the low geared aspect of the truck. One of the aspects is a bug-out truck or a hurricane assistance/get-around vehicle.
91W350
57
Salina, Kansas
I think your 50mph assessment is pretty close. 60 is leaning on it pretty hard. If you are like a lot of guys and consider the 6.2 a throw away engine, 60 is no problem until you cannot keep bearings in it. They have a nasty history of beating the webbing out of the block...then spinning main bearings or breaking cranks. GM improved the block for the 6.5 but it did not work either. Slowing down or cutting rpm is good advic, if you are concerned about engine life or having something to rebuild.
2deuce
147
portland, oregon
As we all know some guys treat all engines as throw away. The 6.2 is a very good engine if you use it as designed. It will last longer than any gas engine but running it at high revs gives it a short life and bad economy.
91W350
57
Salina, Kansas
That is very true, the 6.2 is easy prey as it is governed way too high. I understand why they set the rpm high, it is just unfortunate that they did. The engine gets an undeserved bad rap. Lots of them made it over 300 thousand in half ton 2 wheel drive with over drive vehicles. Very few made it to 100 thousand in low geared applications. My buddy that runs the major engine shop in this area calls them junk bas***ds that always have a broken block, crank or both. They were developed as an economy engine before the diesel power craze took off. I always liked them, I wish they had a better injection pump, but we live with what we got. Glen
junkcurator
st.anthony in
i got pulled over for that my window is slightly tinted and it was at dusk in jasper Indiana. younger officer didn't get wrote up but was told that i have to have a plate light. i asked him where to put the plate he told me "where it belongs" then asked him how that will work with the original equipment penile hitch. explained that the truck was m1028 military ext. he told me to figure something out and have a good evening on the top speed mine likes 60-65 have had it to 80. it has specially tires of America 9x16 on it get around 20 mpg
Keith_J
1,319
Schertz TX
Another hard dying myth. 3300 RPM is not hard on these engines, 27 year old harmonic dampers ARE. The rubber ring in the damper turns to stone, negating all harmonic damping characteristics. That is what kills these engines.
Jozseph
New York
[SUB]Photo is from fluidampr web site[/SUB]
FWIW........
Consider installing a Fluidampr if you intend to keep the vehicle a long time
Review the following article's;
"How It Works: Viscous Dampers, A.K.A. Harmonic Balancers"
http://www.dieselarmy.com/engine-tech/engine/how-it-works-viscous-dampers-a-k-a-harmonic-balancers
And;
"When To Upgrade Your Harmonic Damper In Performance Diesel Applications"
http://www.fluidampr.com/news/when-...amper-in-performance-diesel-applications-119/
Regards
Joseph
