M103a3 powerplant switchbox
Dog Breath
123
33
Wisconsin
I have a powerplant trailer with two 003a’s. All parts seem to be there except for the internals in the switch box. I cannot find any info for the box or any for sale. Any help would be appreciated
Ray70
6,662
West greenwich/RI
I can confirm it will work. I'm using that style synchronizing switch to switch between an 002 and 003, depending on anticipated load.
The best part is you can synchronize and switch under load, the original 002/003 switch box was not a synchronizer, it was only intended to transfer the load from 1 gen to another for service reasons.
runk
66
Houston, TX
If you are looking for the information on the original box, you need TM5-6115-633-14&P. (I think it's in the TM section here.)
. POWER PLANT
. AN/MJQ-18 ( NSN 6115-00-033-1398 ) (2) MEP-003A 10 KW 60 HZ
. GENERATOR SETS M103A3 2-WHEEL, 1 1/2 TON MODIFIED TRAILER
The transfer switch in my box is an Electroswitch, attached are some catalogs I found. The part number in the TM references several other manufacturers in a current search.
