M105 Bow Parts Needed
bachman502
58
Chesapeake, VA
Hello to all. Im looking for six of the stakes that on one end they connect to the ninety degree piece and the other end slides in the sides of the racks. They are 14 1/2 inches long. Didnt know if anybody had some missing or busted bows that they would part with. If nobody has six I will take what you got, just let me know the price. Thanks
builder77
I might have a set of not so nice wood bows that would have them. You might be better off making your own new ones though as I don't thing there was anything unique about these verticles. I will check tomorrow to see what I have.
dirtyfingernails
Gainesville, FL
They are different on the M101. At least on mine they are. My M101A1 has wooden staves that are "covered" with a piece of sheet metal. I'll try to get a pic. The M105 short staves are all metal.
builder77
Here are some pics of the older style M101 bow corners with the wood and sheet metal verticals. One thing that should be pointed out though is that there is not difference between M105 and M101 bow corners in at least the ones I have seen. Even some of the newer ones use the same center piece. There are just two sets of holes and you just bolt in the one that makes the correct length for the width of either a M101 or M105.
bachman502 I have finally gone through my bows, and I have what you need. They are like the ones on the center and right up that pic of mine you added above. I'll call you tomorrow.
