NotThatGuy
- 58
- 18
- Arizona
Anyone have the Roof Measurements of an M1078?
Have a decently accurate cad model I modified. What do you need specifically?Anyone have the Roof Measurements of an M1078?
If you were closer I'd pick it up and get some Sticky Fingers at the same time.I can send you a whole roof
Yeah you’re a bit of a drive…..too bad, I have a smashed A1 cab that’s going to scrap soonIf you were closer I'd pick it up and get some Sticky Fingers at the same time.
Thanks for the offer.
@wheelspinner - I am in need of the driver side metal door stop (the one that is at the bottom of the door). I'd be happy to buy one off of your smashed A1 cab if it is still on there. I've pasted a picture below of mine (the spring steel broke at the detent).Yeah you’re a bit of a drive…..too bad, I have a smashed A1 cab that’s going to scrap soon
Those are essentially always broken in that exact way on every truck and if you buy a used one that isn't broken it will be shortly. Use that information however you like.@wheelspinner - I am in need of the driver side metal door stop (the one that is at the bottom of the door). I'd be happy to buy one off of your smashed A1 cab if it is still on there. I've pasted a picture below of mine (the spring steel broke at the detent).
You have the left side driver kick panel?Yeah you’re a bit of a drive…..too bad, I have a smashed A1 cab that’s going to scrap soon
Good to know. I do (did) like having the detent to keep the door from closing when parked on an incline. If I could buy a used one for a reasonable price - I’d go that route.Those are essentially always broken in that exact way on every truck and if you buy a used one that isn't broken it will be shortly. Use that information however you like.
I don't think you understand. Outside of a brand new truck or a brand new door for a truck - I would wager no one here has ever seen one that isn't broken. Buying a used one is a waste of money because buying a new one is likely a waste of money. They sucked and never got redesigned - the redesign was the armored cab and those have gas shocks. They broke almost immediately. My truck - a 2008 A1R, and one of the last soft cab trucks manufactured - had 2,045 miles on it. Broken. So how long do they last? Not long enough to be worth your time or money is the answer.Good to know. I do (did) like having the detent to keep the door from closing when parked on an incline. If I could buy a used one for a reasonable price - I’d go that route.
2007 with 1800 miles, not broken here, although pretty rusted. Have too long a list of items to be replaced already.I don't think you understand. Outside of a brand new truck or a brand new door for a truck - I would wager no one here has ever seen one that isn't broken. Buying a used one is a waste of money because buying a new one is likely a waste of money. They sucked and never got redesigned - the redesign was the armored cab and those have gas shocks. They broke almost immediately. My truck - a 2008 A1R, and one of the last soft cab trucks manufactured - had 2,045 miles on it. Broken. So how long do they last? Not long enough to be worth your time or money is the answer.
Have you looked at the spring steel inside the track? It doesn't fall out and isn't always apparent that it's broken till you remove it from the door.2007 with 1800 miles, not broken here, although pretty rusted. Have too long a list of items to be replaced already.
Got it. Thanks for the further clarification. Usually I'm not that thick. Guess I just live without or find some other solution.I don't think you understand. Outside of a brand new truck or a brand new door for a truck - I would wager no one here has ever seen one that isn't broken. Buying a used one is a waste of money because buying a new one is likely a waste of money. They sucked and never got redesigned - the redesign was the armored cab and those have gas shocks. They broke almost immediately. My truck - a 2008 A1R, and one of the last soft cab trucks manufactured - had 2,045 miles on it. Broken. So how long do they last? Not long enough to be worth your time or money is the answer.
EXcap in Germany sells them though I can't seem to access the part of the site that has replacement parts but I've seen them beforeThose are essentially always broken in that exact way on every truck and if you buy a used one that isn't broken it will be shortly. Use that information however you like.
