So CTIS cycles and the tires start to deflate? If so, look for an obstruction in the PCU vent line. This line runs from the plastic cover on the bottom of the PCU to a port in the floor. You can disconnect the line at the plastic cover to take that line and floor port out of the equation.
Basically if the PCU cannot vent cleanly to 0 PSI, it will hold the wheel valves open and the dump valves will dump tire air. This is how the PUU deflates, it sends the air to a 6.5PSI relief valve which vents the PCU down to 6.5PSI. Anything over ~5PSI is enough to hold the wheel valves open. The dump valves mimic this 6.5PSI from seen from the truck side, by venting any tire air above 6.5PSI.
Have seen this issue numerous times, Usually due to Mud daubers/insects trying to nest in that floor port where it goes thru the cab floor behind the grill. If that is the case disconnecting that line between floor and PCU bottom plastic cover will allow it to vent to zero. That or your PCU control solenoid is not opening cleanly, but you said you swapped it...
