61sleepercab
- 3
- 0
- Walton, West Virginia
Long winter night and dreaming of M109 camper/man cave project to start when I get truck from Pa.
I have looked at Ammo Can /freon/propane stoves for ideas of a compact heater for the M109 box. I want to keep things compact and close to box wall by using shielding and fireproof material in Box wall .
Has anyone seen/built a small stove with a bottom air inlet that could be ducted from the outside for combustion air?
My idea is a 2" air inlet pipe through the box wall for inlet air with a damper control cap on a threaded rod to open and close air intake and a removable chimney for transport . I want to avoid a roof hole if possible for the chimney due to leaks and tree limb removal when on rural roads. Any ideas out there, based on combination of 50 cal. ,20mm cans?
How would the old multifuel Army tent tin can stove work in the real world? Thanks for input, Mark
