M109A2 vs M109A3
Rodger
Placitas, New Mexico, USA
Hello All
I am looking for a truck to camperize. Currently we are using a Pinzgauer 712AMB and want something larger.
Can anyone explain the differences between a M109A2 and a M109A3 ?
Thank you
Rodger Kitt
fuzzytoaster
3,059
Fort Worth, Texas
This topic has been covered before. If I remember correctly no...just the A3 was serviced more recently compared to the A2. A1 is a steak sauce. :roll:
goldneagle
935
Slidell, LA
All i could find on the subject was that the early M109's had 5 windows on each side of the box. Later they changed it to 3 windows per side. This does not explain the difference between the A2 and A3 versions. I will keep searching.
Castle Bravo
Hundredaire Socialite
225
Arizona
I've wondered this too.
Presumably, the M109 is the gas powered truck. Likewise, the M109A1, A2, and A3 include the LD427 and LDT465 engines, with some other modification in there too. The M109A4 is the Caterpillar powered Allison Transmission version (M35A3 equivalent).
Rodger
I found this on a previous thread. (Thank you)
How do I tell which engine it has?
When built, the M109A2 was powered by the LDS-427 Multifuel engine. When the LD-465 was introduced to the series, the model number changed to M109A3 - and stayed the same with the introduction of the LDT-465.
Many (virtually all) of the M109A2 trucks have been repowered by the military with 465 engines, blurring the distinctions.
Hope this helps,
David Doyle
goldneagle
935
Slidell, LA
Hope this helps,
David Doyle
Well that answers the question! I guess mine is now updated to a M109A3 since I have a new LDT-465-1D with 98 hours on it. :beer: :mrgreen:
593
12
Ville Platte, LA
Fella on another board says the LDS-465 was the last iteration of the series, that it was intended for the 5 tons but was put into some Deuces, and that it generates roughly 200hp.
I am not familiar with all the different engines put into Deuces, does this sound right?
LC
goldneagle
935
Slidell, LA
LC
The A1's had Continental LDS-427-2 ( built under the MANN diesel whisper engine licence ) Multifuel turbo engines, and 5th gear was an overdrive.The engines were not reliable. A2 trucks received the LD-465-1 non turbo, keeping the OD transmission of the A1s. Through the years the trucks were upgraded to LDT( turbo clean air)-465-1A, B, C. The turbo was added more to clean up the very black exhaust on the Non Turbo engines, than to add power, the HP was only raised from 130 to 135 HP. The LDT-465 D was the last version of the Multi Fuel, it had a Quieter Turbo ( non whistler )better head gasket sealing and head cooling.
593
12
Ville Platte, LA
Thanks, GE. Are you saying there is no such thing as a LDS-465 for the Deuce? I am pretty new, don't know a lot about what was in the older vehicles (or any of the vehicles, for that matter.)
But I am trying. :mrgreen:
LC
