M109a3 -AC anyone installed a AC unit
digitaldust
Twp Flint ,Mi ,
Has anyone installed a air conditioning unit in there M109a3 ?
I'm wondering what it looks like.
Would it be better going with a wall unit on the front of the box above the cab?
would a roof top AC be too high ? for low bridges.
If you have pics please post them.
SCSG-G4
PSVB 3003
3,272
Lexington, South Carolina
You need to search the M109 conversions threads. Both have been done. In the front, over the cab can be seen in the "A Different Kind of M109 Conversion".
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
My wife and I use a roll around AC, and just run the hose out the little front door. We are going to go to a window unit in the front though, easier and doesn't take up floor space.
peashooter
205
Hanover, minnesota
Yeah going with the front window area is pretty easy. I ended up getting a 8000 btu ac unit from costco (since they have a never ending return policy). I made a frame in the window area for it and covered it with some aluminum panels. I ended up making a cover for the outside of the AC unit also that has a 24v linear actuator that lifts it up and down. The actuator was an afterthought as I was originally going to do it manually but once I realized how hard it was to reach that area I put the motor on.
A cover has come in nice. The fins on ac units now are soooooo thin, they bend if you just look at them wrong. Also I found I would get leaks after heavy rains and if the truck wasnt level. Also added a drain tube running down so that it doesn drip on the cab anymore.
Like magneto said get enough cooling capacity. I quickly realized why almost all RV's are white....they get blazin' hot in the sun otherwise. It takes a fair amount to keep these things cool. I'd recommend looking hard for the highest BTU capacity you can get that will fit in the window or whereever you put it.
Prankster
Ponca City, Oklahoma
I have two lines of thought: you could use an A/C unit from a RV, or a camper. I would sit nicely on top of the cab, and it is not too hard to install. Then there is always the boxy Reefer unit. It runs on its own fuel supply. It seems the term overkill is what these trucks will need.
n2ojunkie
clio, mi
Travis I have a roof mounted unit, not sure if it needs recharged or not but its complete. I changed my plans and I am going with a window unit. If you want it call or text me.
