HookEm
- 33
- 13
- Central Texas
First off, thank you all who run this site for all of your help. I've been enjoying my HMMWV due to much help from you all.
I acquired this ?07 M1152 in non-running/driving condition but have had it operational for at least the past year again thanks to help from members on this site.
Most recently I noticed a sizeable power steering fluid leak around the area of the steering gear (more to come). I had known there was a small leak around the pitman arm that I assumed was the culprit, however once I put the HMMWV on the lift intending to replace this I cannot reproduce the leak. Instead I noticed the brake pedal, when pressed has a significant whine and am wondering if perhaps the hydroboost is at fault? I did confirm there's still plenty of power steering fluid in the reservoir.
I'm considering going to town with some mineral spirits as there's a fair bit of grime everywhere making accurate diagnosis difficult here but was wondering if anyone else has had similar condition and maybe had success fixing. I have been reviewing a recent Technical Bulletin with service/diagnostic procedures. Just figured I'd check here as well.
