M1152/M1123 Startability
ssgtcampbell77
Staff Sergeant
227
St Louis MO
I need some help. Im in St Louis and the last couple weeks the temps dropped into the single digits. WIth in 4 days, I had 6 of my HMMWVs go down. Went through the basic troubleshooting and came up with nothing. Broke out the 20 manual and came down to bad fuel injection pumps. On 6 trucks. At the same time. Today, temps in the high 50s, all but 2 trucks fire right up, no problems. Im lost and nobody can give me a straight answer. Thanks in advance.
Westech
CPL
6,104
208
cow farts, Wisconsin
Is the glow plug light on? we had a HUGE problem with the controllers not working on our 1116's. Give a tap to the controller before starting and power on, also make sure the driver has his foot to the floor if below 32 and 1/2 way if above. Another trick is to plug the exhaust pipe with a clip board while starting. You can cycle the glow plugs like 4 times too and see it that helps. Happy hunting, but I would NOT think the pumps are out.
ssgtcampbell77
Staff Sergeant
227
St Louis MO
Using regular Diesel from the local Cirlce K. Glow plugs and controller are fine, put my foot through the floorboard. Nothing. When the trucks didnt start, i traced the fuel lines. All was good going into the pump but nothing coming out. Then for ****s and kicks, tried to start them again yesterday and 4 of them fired right up.
jwaller
19
Columbia, SC
sounds to me like to had water in the IP that froze and would not let fuel thru. either that or your fuel gel'd up and would not flow.
you can open the fuel filter drain while cranking and see if the lift pump is giving proper feed to the IP.
Hauling4you
La Crosse, Wi
I will give you the suggestion we used on all of our HMMWV in the army. After the trucks sit for a little bit they never wanted to start, ever. when I say sit I mean for a whole 5 days at a time before we started them for "maintenance". Take a sturdy book and hold it over the exhaust while attemping to start it, the back pressure always did the trick to get them started no matter how long they had set.
Dave
ssgtcampbell77
Staff Sergeant
227
St Louis MO
I tried the back pressure trick but that didn't work either. Im at a loss because now that the weather warmed up, I have no way of troubleshooting the system. Thank you gentlemen for all the suggestions.
ssgtcampbell77
Staff Sergeant
227
St Louis MO
Update - Stiil haven't found an answer to this problem. Temps are due to drop down again next week, I guess that will give me more time to figure it out!!
ClarkeF
Hestand, KY
Do you get any smoke out the exhaust when your cranking? If so, what color? Is the speed at which it turns over fast or slow? If slow, use a slave cable from a running truck to help spin it fast enough to get it to catch. I assume the "wait to start light" is operating normally? Have you tried cycling the wait lamp several times before cranking? After the wait light goes out, push the throttle to the floor and release while cranking - that helps the cold advance solenoid take hold over a weak spring (which as a new truck you shouldn't have these problems...)
ssgtcampbell77
Staff Sergeant
227
St Louis MO
Got grey smoke from the exhaust, truck was slaved, starter is fast, cycled the plugs 3 times. I will try the throttle thing when it gets cold again. Thanks.
Varyag
Garfield, Washington
Tell one to hold his Kevlar against the exhaust and the other to floor it and hit the starter. Usually does the trick. This is how we got the ones we had in Bosnia to start on the cold days.
ClarkeF
Hestand, KY
White smoke is unburned fuel. You have a failure in your glow plugs, gp circuits or your control box. Try swapping the control box from a truck that starts with one that doesn't. Use the TM for troubleshooting starting problems.
ssgtcampbell77
Staff Sergeant
227
St Louis MO
I tested all glow plugs and gp circuits...controller.....PCB....ran all trouble shooting diagrams in the manual. Nothing. I had a 3rd echelon mechanic fly up from Texas and he confirmed that the pumps were all bad. Is it possible for cold weather to jack up a IP?
TedG
MI USA
Have you used a fuel additive lubricant, like Stanadyne, to keep the ip's lubed when using ultra low sulpher fuel. Also, check the fuel return lines for fuel/blockage.
