M123 1400x24 tires needed
CanadaDeuce
Nelson, BC, Canada
hi Guys im on a search for a few good 1400x24 NDT tires for a M123 10 ton tractor, yup read posts seems hard to find, if ANYONE out there has a few good ones with or without rims pls contact me , maybe its time to contact China and get some new ones made and do a bulk purchase, I know there not made in USA but at the size of them Chinese would be the only way to afford them HAHA
I also need a handful of other parts for the truck if anyone is parting any out .
tks Terry
NDT
6,091
Camp Wood/LC, TX
Try B and M Surplus in upstate New York, I got two nice ones from him a few years ago.
CanadaDeuce
Nelson, BC, Canada
tks for that tried him he had a few now has 1 left and its marginal and wants close to $ 700 for it , can you say don't think so ..... must be someone in north America that has 2 good ones horded in a shop someplace
simp5782
Feo, Fuerte y Formal
9,317
Mason, TN
Memphis equipment may have some. They still have a few 123s laying around.
We have 1400-24s but they are offroad only.
CanadaDeuce
Nelson, BC, Canada
YUP called them too nothing she said they checked the yard , Winer has some but all cracked. can all the M123 owners please stand up HAHA, need 2 tires and a few other trinkets.......... gotta be some around someplace
simp5782
9,317
Mason, TN
What is the brake drum diameter? Maybe make a 20in bridge truck wheel work. Then use 1600s with tubes.
Sent from my SM-G935P using Tapatalk
NDT
6,091
Camp Wood/LC, TX
Red River Parts has a few so so ones on rims. They are all so so as they were last made in the 70's.
CanadaDeuce
Nelson, BC, Canada
I don't think that will work but cant measure it right now, plus I do believe that the inner hub hole is larger to go over hub. Ill find some just gotta shake the bushes
tks for the help .
red
22
Eagle Mountain/Utah
I remember reading on here that the 20" wheels can be made to work with some grinding on the axle for clearance.
Looks like finding tires has been a problem for over a decade on these.
Edit: (correction, lug pattern issues apparently)
simp5782
9,317
Mason, TN
or some 21in x 15 inch wheel that they are using with the 24R21 tires is a possibility.
MotorTMan
Aliquippa, Pa
I just recently sold my M123 and for the 5 or 6 years that I owned and restored it, I searched for extra tires constantly. Checked Winers, Adelmanns, etc.. to no avail. The tires they did have were beyond serviceable, and would have probably fell apart after a few miles. I found 4 NDs on EBay that came off a scrapped military grader, good rears, but marginal at best....Good luck on your search
Andy1234
13
St. Louis, Missouri
20" PLS wheels (large bolt pattern) will match the bolt circle, but will hit the air cans.
385/95R24 Michelin or Bridgestone tires (OEM on M911 trucks) will fit perfectly, an exact replacement that is 25+ years newer and radial construction. TNJ Murray used to have them, you will need radial tubes and flaps as well as the tires.
