Thanks Pop, I own a WC-54, so I'm quite familiar with double clutching. I tried double clutching the Mutt today and it still popped right out of 2nd. I also tried just putting it in second gear without anything moving. No go! It wouldn't stay in gear even with the engine not running. I decided to take it for a drive to keep it limbered up and the batteries charged. I put it in reverse, backed up about 10 feet, put it in first to pull forward to head down my driveway and it acted like it was hung up in reverse and 1st gear (brake was definitely off). The Mutt wouldn't budge, engine stalled. I kept trying other gears and reverse again, still no go. I kept moving the gear shift lever, which felt really sloppy, and finally put it in each gear, then started the engine put it in first and it pulled just fine. I pulled it back in front of my shop and left it be. Something is way out of sync somewhere.
