M151 serial #
moose53
Bordentown NJ
unfortunately, the data plate is the only location on a mutt you'll find that number. there is a tag with a sequence number, but that is not a serial, and there may be duplicates from other production runs. On Ford's the tag is centered at the top of the firewall, on AMG's it's on the transmission hump, driver's side, behind the fuel lines. Early m151's had a foil tag on the passenger side frame near the front axle. probably your only shot is if you sand the hood and/or dash you may find it stenciled there...
Jim
