M211 air cleaner part needed
M215
Spotsylvania, Virginia
Hello SS,
I'm in need of the large gasket / O-ring at the bottom of the M211 air cleaner housing. This is the gasket that the removable bottom pan seals against, the diameter is approx 8" across, unlike a O-ring it's profile is more flat or square.
Part #7410792
Checked with Memphis and Alfahaven, no luck.
Any of you guys want to check your parts trucks for one? I'll even buy the whole air cleaner assembly if it has a good gasket!
Thanks,
Karl
deuceman51
10
Scotland South Dakota
Not sure if I have one on hand or not. I will try to check this weekend. Otherwise maybe put some gasket material on the bottom in a nice bead, let it cure and then it should seal up like the gasket in question. I've done this before and it works well, especially since it isn't under pressure.
