deuceman51
- 10
- 18
- Scotland South Dakota
I started to tear into my brakes to inspect and check out the seals and wheel bearings and had some questions. First, there is very light rust in the inside of the housing and on the metal of the brake shoes. Can you paint these areas (excluding the actual brake pad that contacts the drum) without harming or running a risk of the heat of the brakes catching the paint on fire? Seems unlikely, but just wanted to cover my bases first. Secondly does anybody have any good step by step instructions or tips for repacking the wheel bearings, inspecting the parts, and retightening the lock nuts ect? I've heard that you should snug them up and then back them off a bit. I've never worked on them before and want to do this right and safely the first time. Thanks.
