M35A Deuce Battery
tmallow2004
Florida
What is the type battery I need to ask for when I visit some place like Advanced Auto or Pepboys or Autozone - for a Deuce M35?
Thanks in advance
TexAndy
15
Bee County, Texas
Also, I believe Exide in San Antonio still makes the big square military batts, new.
Another thing you might consider is putting a battery conditioner/charger with a desulfation mode on them. I got a 24V batteryminder that *appears* to be working on mine.
Keith_J
1,318
Schertz TX
Sweet! Remember, lead sulfate is the product of battery discharge (which is why the specific gravity drops) and it doesn't conduct electricity very well. This leads to poor capacity from regular charging and use. Deep charging converts this lead sulfate trapped deep in the plates back into lead/lead oxide and sulfuric acid. Lead oxide is the cathode
Either get a good battery hydrometer (floating ball type) or if you are a true gear nut, the Leica refractive type like mkcoen's. Yes, I need one of them. :roll:. And charge according to the hydrometer, not the voltage or automatic cut off.
Why? Capacity is a function of the plate mass and is balanced by the electrolyte. As batteries age, they build up sulfate, the alternator's regulator cuts off the charge rate early because it only "sees" voltage which is a function of the surface charge, not charge at depth (plates have a thickness).
jollyroger
Centennial, Colorado
You sound like my Pop's. He owns the first new electric car dealership in Colorado. He tells me ALL about how batteries work. I suppose it helped being a chemist as well. Batteries. Simple but not so simple. There really is a lot to it.
m109guy
27
ON
I bought mine at NAPA. Commercial truck batteries. #31-110S
1125CCA / 1260CA
They are more expensive than regular car batteries, but they get the deuce started on the first try every time. The are also great on those -20F days we get up here in the winter.
