Dieselking22
- 1
- 0
- Mocksville/ Winston-Salem, NC
Okay my m35 has been hard to start lately because the batteries are dyeing fast. I took them out the other day and charged right up. Put them back in and put a volt meter to the slave cable receptacle and it measured 24.9 Volts (after charge) So i got it running again and put the volt meter on the big wire coming off the Generator(the wire going under the generator cover) and it said 24.99 volts.
My question is how do i check the generator to see if its working properly? And i adjusted the Allen bolt on top of the gen. to see if the reading would change but i did not.
My voltage gauge stays about in the yellow regardless if the switch is on or the engine is running.
Heres some pics below
Thanks guys.
Corey
Thanks guys.
Corey
