M35a2 keeps blowing headlight
Bobweb
163
Morganton, Georgia
My driver side headlight keeps blowing. Any suggestions on what the issue could be? I took apart all the connections and checked for bad wires. They all looked ok. cleaned ground to the frame, re-assembled. Stayed bright for one run, next time I turned the service/drive selector on it blew again. I am not
Much of an electrician. Any help would be appreciated. Thanks
Barrman
1,730
Giddings, Texas
It reads like a wiring issue for that one side. However, the rubber isolators for the headlight panel are there for a reason. There is also a note in the 1964 TM about making sure the idle speed is high enough for just this reason, blown headlights because they got shaken to death. 850 is stuck in my head.
glcaines
2,548
Hiawassee, Georgia
I had a similar problem with one headlight on an M35A2 I used to own. I went through three Chinese manufactured headlight bulbs, all on one side, in about two months. I believe they were leaking air because when they failed, they flashed and turned black. I then found an NOS Sylvania headlight bulb and never had another problem. The other side already had a U.S. made bulb.
Bobweb
163
Morganton, Georgia
That almost sounds exactly what happened to me. When I bought mine, driver side was dimmer than passenger side, but would turn on/off consistently, without fail. I went to adjust the beam height and cracked the headlight glass. Purchased a new one/installed and blew immediately. Ordered a new one, installed, drove once and then blew again. The pictures are the third new one I have bought after the original I received with the truck . I want to figure out what’s going on before I install this one cause it’s starting to get expensive!
HDN
5,019
Finger Lakes Region, NY
I just looked up that listing. It looks like they're shipping surplus sealed beam headlamps. I'd think they'd be good to work with your truck without issue, so I'm thinking it's either an electrical problem or the idle is set too low like @Barrman mentioned. Your voltage should read around 24 volts at the lamp contacts. The truck, when stock, should be 24 volts everywhere.
Bobweb
163
Morganton, Georgia
Ok im back. Tested and got 24.86v
picture of the blown headlight
grounds have been cleaned at the frame
wires are rough but no metal showing
any other tests you guys can recommend? I’m looking at the tech manual under trouble
Shooting but not having much luck
WOLF DOG
135
33
Eastern Shore MD
I think you got some bad headlamp replacements. Several years ago I recall hearing about a bad batch of lamps being distributed at MV rallys and shows, don't remember the brand. I've experienced the same scenario but mine were both sides. Also I feel that if you were having a voltage surge, it would be blowing out all the lights that were turned on when the surge occured. However with these older trucks being simple 24v systems (no electronics), I don't really see where a voltage surge or spike could come from. A bad ground won't create a spike in voltage.
Bobweb
163
Morganton, Georgia
Well, I think I’m going to hold my breath and plug the new one in. If it blows again, I’ll find a new person to order from or go the direction that gopher hill recommend
WOLF DOG
135
33
Eastern Shore MD
Bobweb, after thinking about this a few minutes, I think you could get a higher voltage than safe for your lighting if the voltage regulator is malfunctioning. However as said before, it would effect all operating lights, not just one.
Bobweb
163
Morganton, Georgia
When I got the truck, the driver side was always a bit dimmer than the passenger side. Any reason for this other than a failing element in the bulb? Could that be the voltage reg going bad?
WOLF DOG
135
33
Eastern Shore MD
I don't so Bob, the voltage regulator controls voltage to all bulbs. They would all be dim if the voltage regulator's output was low and your batteries would go dead
