Big Strapper
- 0
- 3
- Nevada, IA
I recently noticed my right tail light was dimmer than the left. When I took the lens assemblies off both, I found the two are not the same, & the right tail light bulb was melting the right lens. This is because the right lens frame is thinner than the left, placing the lens too close to the bulb. The left tail light also has a cube with LED looking lights in the bottom of it which the right does not have.
My question is, should both sides be the same, or are they supposed to be different? Has someone put an incorrect tail light on? I know the bulb should not melt the lens, so something is screwey.
Any feedback is appreciated. I apologize in advance for not understanding the black-out lighting system functions.
