skinnyR1
- 16
- 18
- Burlington CT
New day, new leaks.
I am getting a leak out of the transmission input, in the bell housing. I have read all of the threads here. I have read the TM.
Many people suggest lowering the oil level to an inch below the fill plug. I will entertain that concept if I can't determine the real cause of the leak. I am following most of the advice from m35-tom. In other threads, he references bolts being loose in the bell housing causing the leak? I know there is no seal in there, just threads throwing the oil back into the trans. Can I tighten or service this through the inspection plate???
There is a root cause to the leak, and I would like to find it. This is a new leak, and wasn't there before. I haven't done anything to the oil level of the trans. No water fording. Just street driving. I have checked the level, and it is where it is supposed to be.
It isn't the rear main leaking. I can see the oil dripping off the pilot.
I will pull the trans if I have to, but would like to leave that as a last resort. If I can do something about this through the inspection plate, that would be ideal.
In the attached pic, is it bolts with #1 that loosen causing the leak, maybe??? I can probably reach those through the inspection plate. Are those bolts drilled through to provide oil flow? I am confused as to how it works in there.
