m35a2 white engine
armyrino
Jacksonville Florida
Just curious. My 1971 m35a2"s oil pressure runs around 30psi while above 1000 rpm and can drop as low as 10-15psi at idol. I've built many engines and I know for some this is within spec. Any input would be great is this normal for the engines?
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Have you put a mechanical gauge in the sending unit port(on the side of the block at the rear, above the starter) to verify the numbers?
It sounds ok to me.
1,175
Normal, sometimes...
Acceptable, yes.
