jpinst
- 5
- 18
- Hong Kong/Long Beach
Seems there is not a lot of information abotu the A3 except one small supplemental manual. its about 175 pages long.
I have been reading the TM for the A3. It says I need 15W40. Is there any brand that is better for this type of CAT engine?
It also talks about the levels, but does not say how much I need to buy to do a complete change.
The allison transmission can apparently take the save 15W40 engine oil, or ATF fluid. Whatever it has in it now, is what I guess I am supposed to replace it with. What is a god ATF for bug trucks, if there is one? In anybody's experience, what is normally put in the tranny?
If engine oil is in there now, can I open it and let it drain for a few hours and then put ATF in it? or vise-versa?
As far as coolant goes, can I just use automotive antifreeze?
How about all the grease points? Can I just use normal automotive grease to inject into those point?
advice and opinions appreciated.
