- 3,657
- 27
- 48
- Dallas, Texas
Looking uin the FAQ I see this info:
M39/G744 Series
Engines
Continental R6602 Gasoline Engine- M39 series
Mack ENDT-673 Diesel- M39A1
LDS-465-1A Turbocharged Mutifuel Engine- M39A2
Transmissions
M39 and A2 series with Gasoline engine or Multifuel engines- Spicer 6352 5 speed/manual (direct)
M39A1 with Mack - Spicer 6453 5 speed/manual (OD)
Is it possible to use the overdrive transmission from the M39A1 Mack powered truck in the M39/A2 multifuel-powered truck?
I also notice the 5-tons use outer axle seals like the 2.5, yet I have not sen anyone complaining of leaking seals, like on the 2.5 ton trucks. Is it less ofa problem on the 5 ton?
anyway I am reading the manuals now, esp. about the axle ratios and the like.
M39/G744 Series
Engines
Transmissions
