goodguyzy
- 13
- 38
- medford oregon
i am apparently the high bidder on a "m44a3" from GSA, here is the description of the vehicle. its a 5 ton a3?
TRUCK CARGO 5 TON M44A3, VEHICLE MAXIMUM GROSS WEIGHT 19580.00 POUNDS; WHEEL QUANTITY 6; DRIVE WHEEL QUANTITY 6; DRIVE AXLE LOCATION FRONT AND REAR; AXLE DRIVE TYPE CONVENTIONAL; AXLE SPEED QUANTITY 2; REAR WHEEL MOUNTING TYPE SINGLE; NOMINAL WHEELBASE 154.00 INCHES; PRIME MOVER TYPE DIESEL ENGINE; MULTIFUEL DESIGN FEATURE NOT INCLUDED; CYLINDER QUANTITY 6; ENGINE BRAKE HORSEPOWER 170.00; ENGINE POWER RATING 170.0 HORSEPOWER; ENGINE HORSEPOWER RATING SPEED IN RPM 2700.0; TRANSMISSION TYPE AUTOMATIC; FORWARD SPEED RANGE QUANTITY 5; FORWARD SPEED QUANTITY PER RANGE 2; REVERSE SPEED QUANTITY 2; WINCH LOCATION FRONT; WINCH TYPE SINGLE DRUM; GYPSYHEAD NOT INCLUDED; MAXIMUM LOAD RATING 17000.0 POUNDS; SEATING CAPACITY 2; CAB TYPE CONVENTIONAL; CAB DOOR QUANTITY 4; CAB ROOF TYPE OPEN; TILTING FEATURE NOT INCLUDED; BATTERY QUANTITY 4; BATTERY VOLTAGE RATING IN VOLTS 24.0; BRAKE ACTUATION METHOD HYDRAULIC; BODY MATERIAL STEEL, CORROSION CORROSION RESISTING; VEHICLE CURB WEIGHT: 14600.0 POUNDS; END ITEM IDENTIFICATION: 2-1/2 TON EXTENDED SERVICE PROGRAM (ESP) TRUCK SERIES M35A3; MAKE: AM GENERAL CORP; MODEL: M44A3; YEAR UNKNOWN; MILEAGE: 3,105, HRS 50.2; WILL START AND RUN. REPAIRS MAY BE NEEDED.
