400
| Heater feed
401
| Heater starting switch to coil and indicator light
402
| Heater starting switch to pump and solenoid valve
403
| Running switch to thermal switch
404
| Thermal switch to heater starting switch
405
| Heater starting switch to motor and indicator light if used
406
| Heater ignition circuit and indicator light if used
407
| Heater in operating position indicator circuit
408
| Oil heater circuit including indicator
409
| Compartment heater circuit, including control unit
410
| Safety valve reset circuit
411
| Ventilation fan lead
412
| Auxiliary generator transfer switch to battery heater and indicator
413
| Heater relay control circuit
414
| Auxiliary generator voltage control reostat to voltage regulator
415
| Feed to special ventilating fan or rotoclone
416
| Ground lead for special ventilating fan or rotoclone
417
| Auxiliary shunt to auxiliary ammeter positive
418
| Auxiliary shunt to auxiliary ammeter negative
419
| Main feed to auxiliary control box
420
| Auxiliary engine oil pressure gauge circuit
421
| Auxiliary engine fuel cut off valve
422
| Auxiliary engine magneto ground
423
| Signal lamp auxiliary interphone
424
| Field telephone auxiliary interphone
425
426
| Ground auxiliary interphone
427
| Tachometer, electric, "A" terminal, send to receive
428
| Tachometer, electric, "B" terminal, send to receive
429
| Tachometer, electric, "C" terminal, send to receive
430
| Tachometer, electric, "D" terminal, send to receive
431
| Speedometer, electric, "A" terminal, send to receive
432
| Speedometer, electric, "B" terminal, send to receive
433
| Speedometer, electric, "C" terminal, send to receive
434
| Speedometer, electric, "D" terminal, send to receive
435
| Rear door emergency warning light
436
| Comp. feed including relay
437
| Comp. relay control circuit including switch
450
| Bilge pump switches feed and jumper between switches
451
| Bilge pump switch to rear bilge pump
452
| Bilge pump switch to front bilge pump
453
| Ignition retard circuit, starter to solenoid through normally closed switch
454
| Ignition retard circuit, battery to normally open side of switch
455
| Two speed generator control circuit
456
| Auxiliary generator disconnect control circuit including the switch
457
| Interphone #10
458
| Engine fan clutch circuit
459
| Control circuit for master relay and indicator light
459B
| Master relay feed
460
| Turn indicator circuit, right, front signal/marker lights
461
| Turn indicator circuit, left, front signal/marker lights
462
| Generator equalizer circuit, shunt type
463
| Interphone #11
464
| Interphone #12
465
| Range finder feed
466
| Range finder ground lead
467
| Light switch to turn indicator switch feed
468
| Bulldozer actuator armature feed
469
| Bulldozer actuator field and clutch feed
470
| Bulldozer control solenoid valve circuit
471
| Winch control switch feed
472
| Winch reverse solenoid circuit
473
| Winch forward solenoid circuit
474
| Front end fuel tank solenoid
475
| Rear end fuel tank solenoid
476
| Transmission fan clutch circuit
477
| Differential filter pressure circuit
478
| Generator equalizer circuit, interpole type
478A
| Auxiliary generator equalizer circuit
478M
| Main generator equalizer circuit
479
| Battery heater control circuit
480
| Wrecker solenoid valve control circuit
481
| Magneto switch feed
482
| Feed to auxiliary engine magneto grounding relay
483
| Turn indicator, right blackout light
484
| Turn indicator, left blackout light
485
| Cab feed
486
| Manifold heater, main engine
487
| Manifold heater, auxiliary engine
488
| Rectifier control to master relay circuit
489
| Clearance lamp service feed
490
| Clearance lamp blackout feed
491
| Parking lights to light switch
492
| Ignition ground, ground mag. switch
493
| Auxiliary generator temperature indicator circuit
494
| Engine decompression control circuit
495
| Transmission oil level gauge circuit
496
| Flood or spot lamp ground
497
| Red flasher ground
