M813 instrument panel lights question
319cssb
221
Easley SC
when i turn on the battery power, my instrument lights will come on, regardless to what the panel lights ar set to . Is that normal? Or did someone wire the light switch wrong?
Ajax MD
1,414
Mayo, MD
No, that isn't right. Instrument lights should not illuminate when the main switch is set to off or if the "panel" switch is set to off (vs. dim or bright)
They will be illuminated on max brightness when the "panel" switch is selected to "Park" and will be illuminated if the top "Service" switch is set to any of the other positions while the "panel" switch is set to either "dim" or "bright."
Clear as mud? Good.
319cssb
221
Easley SC
What you say, Ajax is how i remember how it should be (as i saw it on other MV). Now what could be the cause? I thought the panel lights maybe wired reverse? But since i have a combination connector in the back of the lightswitch that seems unlikely.
What should i look for ?
Ajax MD
1,414
Mayo, MD
Well, like you, I'm new to owning and maintaining these trucks so I don't have a sure-fire answer. I would start by tracing one of the instrument lights back into the harness, and to the multi-function switch, checking for illegal wire splices and making sure that the instrument lights are plugged into the proper wire.
