M817 Tach Cable
Tackettr
Edmond/OK
Does anyone know if the duece tach cable will work on the 809 series 5 tons? I have a new replacement cable that works on the duece but the numbers don't match the parts book for the 5 ton or the duece. My 817 is at my dad's farm so I can't just walk out and check it. I'm trying to get parts together for my next trip down.
Here are the numbers on the replacement cable;
6680-00-089-2005
CAGE 65496
PN M10215-1F109
Thanks!
Tackettr
Edmond/OK
Hammer: Thanks for the help, that's what I needed to know. Was it too short or the one end didn't match?
It appears the replacement one I have is some type of universal speedo or tach cable and why the numbers don't match.
Guess it's time to order one.
Hammer
398
Winlock, WA
Yeah, same thing with mine, worked for a while, then stopped working.
Looks like it is the universal speedo.
The deuce tach cable is almost the same length as the 5 ton cummins one, but the end that goes into the IP is not correct. The drive/pin is too small in diameter, and the flat side is not enough to engage the drive in the IP.
Hammer
398
Winlock, WA
Yeah, I know, I did the same thing myself.
Btw, Saturn Surplus shows the correct 5 ton tach cable. I need to order one from them still.
