m818 brake problems "HELP!!??"
atvcat33
muskego Wisconsin
afternoon to my fellow mv owners. took the semi down to the race track and while in line for tickets starting and stoping and clucthing all the time my brakes faded out to the point i had it to the floor and i was using my handbrake to stop from hiting the truck in front of me. whats going on, and then when i went to leave i had brake pressure all the way home half hour away??
i bleed the brakes last weekend. i started with the farthest rear axels then did the front then the master and then the bleeder on the line leaving the airpack. did i miss one or i do it wrong? i had the truck running with air pressure. they are really sensitive when they do work. seem wo want to lock up easy. any help id appreciated.
also when i do pump the brakes all the way it makes a swooshing sound that come out of a 3/4 tube off the air pack sounds nothing like a real semi valve. is that normal too. my m35 doesnt make that silly swooshing sound, and the brakes on the m35 are like the brakes on a new truck very smooth and gradual.
Westech
CPL
6,104
208
cow farts, Wisconsin
the air sound is ok... the 800's vent the air pack air to the out side while the deuce vents it in to the vent line system. sounds like maybe the master cylinder is starting to go out. They will work one min and there will be nothing there the next. It does not sound like a "brake fade' you would have smelled burning brakes and seen smoke if that were to happen on the 800.
