M880 body on newer Dodge truck frame
b17goinmyway
Darlington, Indiana
Hello, I am sure this has probably already been done at some point but I have always thought about taking one of my M880's and placing the complete body onto a later model Dodge truck mainly from the 1980 to 93 model 3/4 to 1ton 4x4's, before Dodge changed over to the newer body style (I think this was in 94/95). I am looking more for a fairly simple bolt on operation with out a lot of modifcation. Will the body mount up to the 4x4 Dodge trucks of the 80's early 90's frame. I just thought it would be neat to have an M880 in looks but sitting on a more modern 4x4 running gear. PS, Dana 60's front/rear, lockout hubs, 360 V8. ect. I suppose one could by a parts truck and swap everything onto the M880 frame but I thought it might be easier to just swap the body over. thanks Dan:-D
N1265
Fremont, Ohio
When I was asking about plow mounts a while back I was told that the Dodge frames from 1973 ? to 1991 ? were the same, But I can not confirm it.....
derek840378
Montgomery, Tx
The same basic design for the trucks was used from '73 to '93 as far as the body is concerned. Now, as far as the frame and any body mounts, I'm not too sure but don't see a reason they should differ.
tm america
24
merrillville in
why not get one with a deisel to .if you get one with a 618 trans you will have od to .that would be really cool and you would have one of the only m880s with a 6bt:roll:
98hd
Reedsburg, WI / Trenary, MI
They should be pretty much the same frame. As far as suspension goes you really aren't getting anything more modern at all. The only reason to swap frames would be to replace a bad one, or if you found a good frame w/ the drivetrain you wanted already installed.
The dodge body from 82-93 only differed in that the exterior panels were modified a little, as in shape and style.
