M916 Super Singles on Front
Construction
North Carolina
Tried to put 22.5" super single rims with 445 65 22.5 tires today on my M916 today and the rims would not fit over the brake drum. The stock rims are 24".
It looks like others have super singled out the front of a M916 or M920? What rims did you use?
86m1028
17
Murphy TEXAS
20" Hemtt wheels with a little creative grinding to the drum and valve stem.
Thats what I used.
As for grinding, I pulled my frt drums & had the outer corner edge machined down to clear the wheel & valve stem.
Search user M920 he posted some pics.
Danl
Lyman Maine
Danl M915A
Post some pics when you get the 395's mounted.
Im running 16.00R x 20's
Here is a pic of one of mine.
Nice job Sir I like that. Hows the power after the increase in tire size, did the tranny have to be recalerbrated, or are you shifting it your self.
Floridianson
2,501
Interlachen Fl.
Cadilac yes I did the drum grind thing but it goes cross grain to what I have been tought. I learned from a friend the MK48 rims and tires will bolt up and match the 16x20 hight. The MK 48 drum has the correct spaceing for the rim /drum clearance. I had extra M916 front ends and I replaced the ground down drums I had cut down with new ones and used MK48 rims. I know the MK 48 stuff can be hard to find but I feel this was a better way to go than grinding down my drums. Here is the diagram if you wish to do it but don't tell them I told you.lol
andy3
12
Suwanee, Ga
Wow that's allot of grinding! That's more grinding than a Miley Cyrus video. I don't think I could watch either being done.
Tow4
646
Orlando, FL
Well, one might be more fun to watch.... But after a while, all those sparks and crap flying at you gets annoying.
cadillac
sheboygan wisconsin
drum
That lip on my drum is only about 1/4 high to start with. How high was yours before you had ground it ? I took alittle off but had no luck yet, but I did not grind much for the valve stem.
