Arny
- 3
- 3
- Stuttgart/BW
I've been reading for hours in this forum now but haven't found a solution for my problem
My M923 A1 has a oil leak on the front axle. Oil drips from behind the axle boot. So I changed the inner oil seal.
The first ride it was all good but after 50mls it started leaking again. I'm really pissed right now as you might know how much effort it costs to change that seal.
Anyway the front axle vent is not blocked - so that can be excluded.
When I removed the wheel I noticed that the wheel bearing had quite a lot of freeplay. So I assumed that was the original reason for the leak since the driveshaft will also tumble (in the oil seal).
Now I'm wondering if the bushings might have been damaged due to that. Is the only bushing for the drive shaft the brass one in the axle spindle?
I'm really a bit helpless right now since I don't want to change the seal again without any effect...
Any ideas?
Any ideas?
