M923 Bob
hawaii5ton
Kailua Kona HI
Day one and disassemble was fairly easy and straightforward. I have seen a lot of pictures on the old interweb here but no trucks like this in Hawaii, so I'll be learning as I go with no reference.
hawaii5ton
Kailua Kona HI
I bought a set of front springs complete with hangers, shackles, and all bolts from E-Bay (shipping to Hawaii from New Jersey cost as much as the springs).
You can see how much of the frame was cut off here.
hawaii5ton
Kailua Kona HI
IMG_2956.jpgIMG_2958.jpgIMG_2959.jpgIMG_2960.jpgRan the exhaust under body, believe it or not there is still almost ten inches of clearance between muffler and tire.
Ran 5" exhaust from cab back and used a stack muffler because it was only 9" diameter. Also I made a turn out through and behind mudflap hanger and painted whole thing with flat black 2000' header paint.
hawaii5ton
Kailua Kona HI
IMG_2964.jpgIMG_2966.jpgIMG_2967.jpgI forgot my camera when I shortened the bed sides and jump seats but here's the finished truck.
Done on the fourth of July and had her maiden voyage in the evening parade.
I had a blast building it and think it turned out great.
bigboy44
Ava, MO.
Great Job, I like it. Can you tell me the turning radius, how it drives compared to the duel axels, and fuel MPG. Thanks
hawaii5ton
Kailua Kona HI
This truck drives great, I have parked it in a single parking stall with no problem. The turn radius is considerably tighter, I would compare to my quad cab pick-up. I can turn around in a cul-de-sac without doing a three point. Not sure about fuel mileage I've only had it done two days now.
hawaii5ton
Kailua Kona HI
IMG_0001.jpgIMG_0004.jpgFinally got a chance to repair and install the top, I think it looks better with it on.
Here's a couple pics. I just pop riveted the plastic strip to the top with washer backers and painted them to blend in.IMG_0006.jpg
No modification to truck, just the top. I couldn't get anyone to sew it on, so this works.
madcroc1
deerfield beach, FL
I see that you cut a middle section out of the bed. can you tell me what the length is of your bed after the shrink job ?
Also how much did you remove of the frame rails ?
