M923 payload highway
MP_1
germany
Hello,
where can i find the payload on the highway in the manual?
I cannot find any informations about the payload on the highway. I should have 20000lb?
best regrads
andreas
1,178
Should be listed in the specifications section of the -10TM.
Also on the data plate on the dash.
Tow4
646
Orlando, FL
You may have to back-into the highway payload. I couldn't find it spelled out in the -10 or on the dash plate of my M929. I did find a table of material weights that listed cross country and highway payloads.
In the table, 20,250 lbs is over rated cross-country and highway payload; 19,238 lbs is only over rated cross-country payload. Knowing that most MVs are rated for their cross-country payload and the highway payload is usually 2X that; I can figure 20,000 lbs is the highway payload of an M929.
1,178
20000 pounds = 9.0718474 metric tons
Tow4
646
Orlando, FL
Sounds like the OP is looking for supporting documentation. That would be either a table in the TM, or a picture of a data plate that shows a 20,000 lbs higher loaded weight than unloaded.
