Ecscnvb
- 1
- 0
- Va beach/va
Did u look at my previous pics?Are we sure the pulley is not pressed on the balancer, and started slipping?
Sent from my SM-G935V using Tapatalk
And if it sitting in your driveway just pull the radiator and fix it right.Above will work, but make sure you strap the ratchet or breaker bar to the frame rail first, otherwise it can come off and fly through your radiator. Also make sure you are going the right way (know engine rotation direction). Make sure nobody is standing in line with it. Tell the dog to stay inside on this one if you go this path.
Are you sure somebody didn't just install bolts that are way too long and their bottomed out on the crank? If that is the case, the bolts could be extremely tight but not even touching the pulley thus the reason it is loose but the bolts are tight. Probably a RRAD truck....Not by hand but when trying to loosen bolts with breaker bar and socket the whole assembly turns
Yep, thats why I suggested it...Did u look at my previous pics?
I will be delivering a in 923a2 to va beach in a few weeks. Guy owns active lawn care there. So you will have another truck in the localWorked on it for a while with no progress. Did something I didn't want to but was so pissed I said f it and did what simp5782 suggested. I was going to do it earlier in the day but I don't normally take the easy way out. I didn't strap wrench or anything, just had it positioned perfectly each time. Needless to say I had balancer completely off in 5 min. Crank is fine, damper pulley just moved inside the rubber part of the assembly. New one with seal will be here tomorrow, baring the weather, for 302+149=$451. Sucks but it's my most important company vehicle and need it to work tomorrow evening so I ordered it from the local cummins dealership. I'm sure I could of gotten cheaper elsewhere but oh well. I'll take pics after dinner and show what the damper looks like for others to compare to. Huge shout out to you all for helping. Couldn't say thank you enough. Nic from va Beach. Anyone ever need anything hit me up. Thanks
I've seen that company. What's condition of truck ur deliveringI will be delivering a in 923a2 to va beach in a few weeks. Guy owns active lawn care there. So you will have another truck in the local
Sent from my SM-G935P using Tapatalk
Decent. was a non rebuilt truck. came from an EMA agency in Arkansas. Non running at the moment. Has not ran in over a two years. Another member bought the A2 truck at the same place and it was running in 15mins I have not spent much time on this one to get it running before it gets to it's home.I've seen that company. What's condition of truck ur delivering
What do u mean by what u said pressed on? Isn't it all one unit and supposed to be pressed togetherHa, think I was the only one to guess right! Price sucks but glad you didn’t have to pull the radiator.
What are the 932a2's going for these days? Not auction but private? Have seen them getting less and less available.Decent. was a non rebuilt truck. came from an EMA agency in Arkansas. Non running at the moment. Has not ran in over a two years. Another member bought the A2 truck at the same place and it was running in 15mins I have not spent much time on this one to get it running before it gets to it's home.
Dampner is on ebay for 250. Crankshaft Seal is around $15 in federal mogul.Where would you guys have gotten it and how should it of costed?
Depends on condition and who u r I geuss. I'm the only one around vb really and everyone knows my truck. Its pretty much flawless though and I daily drive it so people know it is reliable. I've been offered 25000. Yes I turned it down. It started as my biodiesel truck after that I just drove it for two years and now it is my tree companies dump truck. I've done alot to it and have about 20 or so in it. Technically it is my 3 year olds truck and when she turns 16 she is going to paint it pink with nail polish and drive it. I told her it's going to take a lot of nail polish but she loves it more than I do. It's also her jungle gym. She was two and a half in that pic. We r crazy. Just to let u know.What are the 932a2's going for these days? Not auction but private? Have seen them getting less and less available.
Two pieces, likely bonded together with a thin layer of rubber, total speculation looking at the pictures and recollection of how other balancers are made. Could maybe pop it apart, clean it up and braze it back together until you can find a cheaper used one?What do u mean by what u said pressed on? Isn't it all one unit and supposed to be pressed together
I saw them on a surplus site for 375. I paid 302. What do they normally go for?Two pieces, likely bonded together with a thin layer of rubber, total speculation looking at the pictures and recollection of how other balancers are made. Could maybe pop it apart, clean it up and braze it back together until you can find a cheaper used one?
