M925a2 rear window stuck
therooster2001
44
Colorado
I have had this problem since I replaced my hard top. It's stuck closed, and really good. I've put some pressure on it, but don't want to bend the window, or having it shatter. I'm pretty sure it's CARC that is holding it together, but there is no other mechanical means that hold these together like hidden screw or lock is there? Any suggestions around getting this window open? Is there a strategic pry point that won't deform anything?
TCD
Mound.House, NV
Howdy,
My 923a2 back window was locked up solid. I cleaned the channels and lightly lubed them. Then I took a plastic "dead-blow" hammer and tapped tapped tapped away. Once I got a little movement I just repeated cleaning, lubing and tapping and now one side freely slides.
This weekend I will repeat the process again and see if I can get the other side to let go and slide.
YMMV...
Good Luck and Happy Tails,
tom n tyler
therooster2001
44
Colorado
I got it!!!!! Used a harbor freight orange dead blow and tapped on everything! I actually got it by hitting against the weatherstipping on the window, not the frame, in parallel with the window, not at it. Back and forth, and it finally moved. Prying didn't do anything. Both sides free. Airflow!
