Csm Davis
- 393
- 83
- Hattiesburg, Mississippi
Okay I will wade in here get or borrow an inspection camera and look in the bell housing through the bottom hole that you can put a plug in or through the access port on the side. Also will be easier to pull just the transmission if you can get a large transmission jack if not, then pull motor and all.
Sent from my SM-G930V using Tapatalk
