M929A2 Coolant Filter Install Question
Postman515
46
Clayton, Illinois
Just finished this install on my 929a2 with the 8.3L but I think I plumbed it in backwards. I plumbed the inlet on the filter base to the bottom of the water pump and the outlet to the side of the block next to the block heater. Right or wrong? Thanks
juanprado
3,060
Metairie/La (N'awlins)
I know the newer series tm has the routing and flow as I double checked mine for the nhc250 when I changed my heater core. I found my heater hoses were plumbed backwards.
WillWagner
2,907
Monrovia, Ca.
Depending on how old the block is, plumbing can go like this, Into the filter from the bottom, center pipe plug, toward the center of the block. Out of the filter into the pipe plug just above the one you used for the inlet. If it is a newer block, there will be two pipe plugs toward the rear of the block, one toward the bottom of the flat part of the casting and the other just above that one on the exhaust side. I'll see if I can dig up a manual and scan it for a pic.
juanprado
3,060
Will, what would be a good location for coolant filter inlet and outlets on the NHC 250 block?
Easiest way is to "t" off the existing heater fittings/valves on the oil cooler and intake manifold going to the heater box. Check my build "major zippidy" for pictures and details.
