M931A2 Recovery - Las Vegas, NV to Phoenix, AZ
Castle Bravo
Hundredaire Socialite
215
Arizona
Myself, M35A2-AZ, groundog, and another friend went to Nellis AFB to pick up a pair of M931A2s and drive them back.
We all left Monday morning from groundog's house and headed up the hill towards Las Vegas. Ate lunch along the way and arrived at Nellis around 5 PM. We stayed the night at the base and went to our GL appointment the next morning. The plan was to tow one 931 with the other.
We checked in at the GL office and went to check the trucks out and prep them for the trip back. The oil and coolant levels were good on the first truck, so we tried to start it, but the batteries were dead. The GL guy that helped us (Eddie, I think his name was - good guy) had a slave cable and started a truck next to ours and it started right up. All the tires needed air, and one in particular was pretty flat. All the fluids checked out and the transfer case and axles were full of gear oil. No tools were present, but half a dozen wasps were. Degreaser kills wasps pretty good. The parking brake buzzer would not turn off. I think something could be wrong with the driveline parking brake.
One of the spring brakes was locked up. These trucks were likely loaded and unloaded with forklifts on both ends, so who knows the last time they rolled anywhere. Perhaps rusted in place from Utah. A few whacks to the brake drum freed the stuck shoes. Once we had this truck checked out and warmed up, we moved it over near the other truck we were picking up and began the process to get that truck ready to go. We checked the axles and tire pressure and removed the drive shafts. Hooked up the towbar, safety chains, and towing lights and hooked the air lines to the glad hands in front of the fifth wheel so that the trailer brakes could be activated by the trolley brake. This truck also had to have the brake drums smacked to loosen the shoes.
At least 3 other trucks were there picking up M931A2s also. At least 7 (including ours) were loaded out that morning, 3 more semi trucks arrived to pick up items as we were on our way out. We stopped and fueled up and had lunch in Boulder City and then headed over the dam and down the mountain into Arizona. I think I like the 6CTA motor - 240 hp moves 40000 lbs of army trucks fairly well, even uphill. We dropped down to 20 mph a few times going up some steeper parts. Speeds were kept to about 50-55 mph for the trip because we were towing. About 1/2 way home, the truck seemed to have been cleaned out and had a good stretch and started to run better. The 931A2 is a rocketship when empty. All in all, everything went well.
wsucougarx
67
Washington State
My parking brake wouldn't shut off either. Found the culprit under the truck...a dangling wire. Simply connect the two dangling wires together and the light/buzzer turned off. Check for unconnected wires first.
groundog
wittmann,az
:grd:good pictures---i like the video best---big thanks to Albert for dropping the driveshafts and Matt and Albert for driving the trucks back--long day
Dukeman
Albuquerque, NM
Yeah that engine really sings. Saw one in really great shape a couple weeks ago at our lake. Really nice truck. Great job! Thanks for the write up. Glad you got home safe.
agazza2
31
Ahwatukee, AZ
Nice write up, thanks for the info about the parking brakes. Did you use a rubber mallet, or something a little more forceful? I will be doing the same trip next week, but then on to Texas. Will be nice going through Phoenix, as I used to live there for 13 yrs prior to 2006. Hope my recovery goes as well as your did. Definitely will pack some tools for the trip, and prepare for the road trip like I did for the ones with GM :)
Castle Bravo
215
Arizona
I used a smaller sledge hammer, maybe 4 lbs.
Send me a PM if you want some contact info in case you have trouble next week.
steve831
oklahoma city
are most police agencies okay with you moving newly purchased vehicles without a title? If so, I'd like to save towing fees and drive them back myself
NDT
6,476
Camp Wood/LC, TX
Until you have your farm tags, former military tags, antique tags or whatever, you are operating an unregistered class 8 commercial vehicle which falls under volumes of regulations of the FMCSA. Any stop by DOT or law enforcement will not be a good experience.
groundog
wittmann,az
:beer:We get a 1 day or a 3 day permit and insurance in AZ. that way we are covered---good luck on recovery---always good to get home safe
agazza2
31
Ahwatukee, AZ
Texas offers a 30 day permit with showing the "Invoice marked Paid". That will just give you enough to transport it back, and the receive the SF97 from GL. Worked out great for my M1009.
