M936 Floodlights - Control Switch - Any sort of Cab Control?
20,379
Looking through the TM 9-2320-272-10, Page 93 it mentions that a control switch -on- the floodlights turns them off and on. Nothing happened when I tried that today. I have two white work lights (floodlights) on My 936. Should have been a third one but the lamp under the boom is missing. (entire fixture)
MY REAL QUESTION is: Should I be flipping some sort of switch inside the cab to allow those lamps to light?
I have done nothing yet with a meter. The screws on the floodlight body (fixture?) are rusty, so I soaked them down with LPS before I wring them off trying to get to the bulbs. Logic says step one is to check bulbs and/or voltage? On the other hand, if there is a "main power switch" in the cab maybe I am hunting a ghost.
Do the Vehicle Service Lights have to be on for the floodlights to function on a M936?
simp5782
Feo, Fuerte y Formal
9,482
Mason, TN
Switch should power all 3 lights when on. Mine run without the main light switch engaged. Just use the test light or meter if you suspect the bulbs are good. They probably aren't though
20,379
If all three should come on with one switch (on the lamp housing) could it be that "nothing happened" be because the circuit isn't complete with the boom light missing?
Those two wires hanging in thin air and no socket leaves an open loop? Maybe?
simp5782
9,482
Mason, TN
Nope. One will run even without the others
simp5782
9,482
Mason, TN
They are actually horrible lights. I would swap them if you are planning on using it at night.
20,379
Will an LED bulb in that fixture help the problem - or should I just start looking for something to really light up the night? Not sure that I will be using it at night, but they should function if they stay on the truck. More the idea of fixing things that "aughta work".
Since I am already missing the boom light, I have been poking around for a big fat juicy LED fixture. The truck isn't exactly "stock" but I was trying to avoid gaudy?
I ordered from the ebay link you sent. I can always resell them later. Thanks Wes.
