Smckerigan
- 14
- 18
- Scottsbluff nebraska
Morning, I have been working on my M939A2 Ctis system for a couple of months since I got it back in September . I have removed all the valve stem cores fixed leaks from the wheel valve hoses and some other small leaks. I have the system working somewhat as it will start to work as the tanks reach 120psi and will pump up one of the low tires on the mid left tire. After 20 minutes or so the only mode I can acheve is the sand setting and it will stay solid but it will never get a solid light on there xcountry or the hwy mode. I have checked and replaced all the PCU orings and did the resistance test on the three solenoid so and they are all at 47. So I reall don't know where to go now now. Thanks sean
