Chuck76
- 1
- 8
- Salisbury. NC
Oil Leak, motor to IP line
As the title states, I have a massive oil leak from somewhere behind the IP. I was tring to fix a fuel issue, and while I had it running, decided to make a 5 mile round trip. I havent seen any oil, other than alittle leaking around the base of the oil filter canisters, leaking. I always check the oil level b4 I start tinkering and running the engine....it was good.
I took off down the roan and got about 3 miles away, and noticed I was looseing oil psi.... got her home, and saw the trail of oil down the drive and the puddle she had leaked. After pressure washing the engine, I decided to change oil and filters, and start looking for the leak. Lost all oil with the exception of 1 gallon. I had my GF start the truck while I watched, as soon as it fires, oil spews out from somewhere behind the IP. It only leaks when its running, and leaks so bad, I cant see it for the oil bath I'm taking..... any ideas?
