74M35A2
- 330
- 83
- Livonia, MI
I believe the factory relief valve of an M925A2 hydraulic system is set at 1800psi or 1850psi or so. I'm looking to add dump cylinders to my cargo bed this spring, and if I can up this pressure, I can reduce the cylinder diameter/weight/size/cost. Has anybody messed with their relief valve, or otherwise know how much pressure the pump can develop if this is increased? Some general cylinders are rated up to 3000psi. I understand that the 1800psi is likely a factory of winch max loading (no shear pin), so I would just install a pressure gauge and not exceed 1800psi when using the winch. This gauge could be somewhat handy and be a possible indicator of winch load, assuming 1850psi is 20,000lb load (depending upon layers of cable). I would also have to increase the pressure delivery hose rating, but I would be switching to electric solenoids by then anyway. I'm targeting to be able to lift the full 10 ton rated bed capacity for on-road. So using simplistic math, wanting each cylinder to push half of that, which can be easily found by using force = area x pressure. Cylinder area being radius x radius x 3.14, then x pressure = force. Some weight will be on the hinges, but I would size it this way to "just be sure". Would hate to have a loader fill up the truck, and the bed can't tilt, and then I' up there for seven hours unloading with a hand shovel until it can tilt. There is also the geometry factor of the cylinder angle not conveying all of the force to lifting straight up.
