Mechanical speedometer delete question?
24fan4life
13
Southern Tier, New York
I'm looking at replacing the cable driven speedometer setup, with a GPS unit, to get away from mechanical failures in the system.
Would I just be able to remove the 90 degree assembly from the transfer case, and block it off with a plug?
If not, what exactly would I have to do?
Thank you for any insight into this project.
papakb
1,184
San Jose, Ca
Mechanical failures aren't that common, my '86 has been running with the original speedometer in it since I got it 18 years ago. I do concurrently run a GPS to crosscheck accuracy and for positional data but there's no good reason to replace it,
24fan4life
13
The speedometer has recently failed on my 1988 M1038. This is why I'm looking into this.
I haven't had the time lately to troubleshoot the problem, and have no idea when I'll get the time to in the near future.
I'm sure it's probably not good to drive it with a broken speedometer, so it's sitting until I get that time, and I was just looking into other avenues to go down.
TOBASH
3,408
Brooklyn, NY
Use the GPS speedometer on your Waze app until you can troubleshoot.
See if speedo cable is properly attached to tranny and speedo in dash. See if center rotating cable snapped and replace if necessary.
Uncommon for actual speedo face to die, but I guess anything can happen.
Driving without speedo is not dangerous IIRC, as long as you use Waze speedo or cellphone speedo app
papakb
1,184
San Jose, Ca
One of the things that does happen to the speedometer is the short flex cable that goes between the transmission and the right angle drive can round off if the drive was run while it was loose. You can replace it by snipping off the end of another speedometer cable and replacing it. Here's the manual info from the -24P manual on page 488:
* 24 PAOZZ 5315014091662 7Z588 30448-D PIN,SHOULDER ,HEADLE.................
Replacing it you unscrew the right angle drive from the transmission, remove the pin and reinstall the new one.
TOBASH
3,408
Brooklyn, NY
I just don't want to chew up the gear in the transfer case if that is what has failed.
That gear turns with or without the cable. It does not need a speedo cable "to protect it".
This is a mechanical system, not an electrical system that needs a grounding harness to dissipate extra energy.
