Member locator map
PWM
Saint Maries, Idaho
I have tried to add myself to the member locator map and I am having a problem. Whenever I load the map I am not on it and at the top it has “modify your coordinates”. I have put my latitude and longitude but nothing happens when I submit it. What have I done wrong?
PWM
Saint Maries, Idaho
Thanks, still no dice. In the “modify your coordinates” area it only gives me the options of latitude, longitude and a short message. I tried the address and zip code ,didn’t work.
1,808
It doesn't let you modify the coordinates. I tried several times to get mine right and just can't. Need to get mangus to delete you so you can start over.
PWM
Saint Maries, Idaho
Apparently the map has me in Maine, I have tried a thousand times to fix the map, it won’t let me change anything, can someone delete me so I can try again.
Lugnut
Herington, KS
I am having trouble changing my Map Location also. I just moved to KS and wanted to have the correct location for the locator but no dice.
