- 2,052
- 57
- 48
- Milford / Michigan
I had my MEP-002A Engine Shut Down Solenoid go bad and shut down my generator. Something internally must have gone bad because it was rapidly going in and out and would not stay in to the "run" position. I ordered an aftermarket one and that one lasted about a total of 15 minutes run time but I am past the 3 month return policy. I bench tested it and it does not work.
What is the best option go to with getting a good quality fuel shutoff solenoid? My original one had a total of 160 hours on it when it failed. Is the OEM one prone to failure? They want a lot of money for an OEM one and was wondering if somebody made any adapters to use another OEM quality one that will perform better? Right now I don't have any faith in OEM Engine Stop Solenoids for these generators. Thank you for your help.
