JimH
- 0
- 6
- Delaware, OH
Picked up an MEP-002a with 400 hours on a M116 trailer (no cover) over the winter at Wright Patterson for $620 plus the GL tithe. Finally found some time to work on it, and it did need some work!
The fuel tank on the inside is the rustiest tank that the radiator shop or I have ever seen. Found one in fair condition on Epay, it should be here next week.
The fuel strainer bowl, and the first fuel filter bowl were both badly corroded, from what looks like long term contact with water. Had spares from the MEP-003a project last year, which I am using as a standby generator for the house. Also, there was a bad hose from the check valve to the injector pump that had to be replaced as well.
Finally cobbled enough stuff together to give it a try last night. It started on one cylinder and shook and rattled, and was kind of scary. After a few minutes the second cylinder started to fire, and it settled down after a few more minutes and made stable electricity. Now to get it all put back together, painted and mounted back on the trailer.
Compared to the MEP-003a that I got from Chambersburg last year, somebody clearly did not maintain this one quite as well. I think I have gotten most of the problems worked out, a testament to the ruggedness and the well thought out design of these units.
The prices of these units continue to climb, but they are well worth the money, because you sure can't find anything close on the civilian market.
