MEP-002A Hidden battery "jumper" cable
ChesapeakeJohnny
Eastern Shore, MD
Mine was under the battery trays, tucked in the frame.
I imagine most of the units to be had at Chambersburg PA will be the same.
Thought I'd post in case others experience apparent missing battery jumper. Didn't see it until I removed trays to replace with Group 24 trays.
Lieutenant
57
Michigan
Gotcha. Some refer to it as a dog bone. Most are not lucky to get it, or the battery hold downs.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
I wouldn't worry about cleaning much of anything around that area....the tray and skid are both Aluminum...not much corrosion
bimota
Campbell, CA
Hey, Napa sells these battery to battery cables to make a 24VDC battery in various sizes. Most of the time they keep one in stock.
What I though you were referring to was the MEP-002 and MEP-003 external battery cable - can anyone identify the cable set that goes from the external plug (below the control box) to ???
bimota
Campbell, CA
MEP-002 and MEP-003 external battery cables?
bimota
Campbell, CA
MEP-003 remote battery NATO Slave Cable
Ok, good suggestion. When in doubt read the manual, problem is these old manuals are long, convoluted and full of strange terminology. But I found it and I;m contributing.
The remote battery connector is used with a "NATO Slave Cable".
So where do I get one and what is connected on the other end?
steelandcanvas
85
Southwestern Idaho
When I bought my 003 from GL, I didn't get the "dogbone", but some very thoughtful person safety wired the battery retainers and bolts to the battery tray. One less thing to buy or fab up.[thumbzup]
scrapdaddy
11
Dittmer, Mo.
That's funny because I got two 003's from Letterkenny last week and mine were tied down also. When I started reading this thread, ran out and looked all under everything, no dogbones!
bimota
Campbell, CA
Lucky, the dog-bones are not inexpensive at Napa but very high quality, mil-spec or close; wire sizes actually to large for the loads starting the 003s.
Can I get some clarification on the Nato Slave Cables? In looking them up there is "new" and "old" styles and adapters. Prices look pretty high at retail, is there a source via GL or do some of you guys have some cables laying in the barn?
My guess is the MEP-003 use the "old" style connector but not sure. Bueller?, Bueller:)
bimota
Campbell, CA
Nonotagain
41
Parkville, MD
The slave cables came in two flavors, a two pin and and a single pin version.
The NATO cable is the single pin version.
Old US is a two pin cable.
I have a few sets of NATO cables, 20' long, 2/0 gauge copper with two NATO to old US adapters for sale.
PM for details.
hmsgoodhope
Great Falls, VA
Hello,
Just came across your post - do you still have the 20 foot single pole NATO Slave /Jumper Cables you mentioned? If you do and would like to sell PM me.
If the ship has already sailed can you put me on target to buy ends so I can fab one myself?
Best regards,
Ed
