metalworker393
- 16
- 18
- Jackson NJ
Hello everybody and how are things going. okay I need some help with my 003. I can't get my 003 to crank,did the continuity test on the master switch with an ohm meter and that passed. I took the cover off of the K3 relay and the K2 relay. When I turn the master switch to crank or start if you would call it, the starter relay does not pull in. The K2 relay (glow plugs) does.
Allright, so the K3 doesn't pull in. So, while I have the cover off I pushed the relay in with my finger. The starter then starts. I check the starter lockout switch to make sure it's not closed. The brass flat metal is actually bent outward. I believe this should allow the starter to crank.
I then took my test light and connected from the 16 ga wire to the 12 ga. wire on top of k3 relay. Turned the master switch to start and the starter cranked. Is it possible the master switch could be bad, maybe work enough to do a continuity test but not to actually function properly? I also made sure the ground near the batteries was clean and tight.
Something else I am looking for, S7. After looking at the diagram I cannot determin where or what is S7. Is that the oil pressure switch on the adapter?
Any help would be greatly appreciated. Thanks and good evening, metalworker393
