hedgehog69
- 2
- 18
- iowa city, ia
I have been sputting a MEP 003a back together. I had a Melton rebuilt engine and a A1 gen head. I used the control panel from the old unit, but it was dead. Bad switch?? I didn't work to diagnose, I just swapped in one from a MEP 002a parts machine. I thought I had read they are the same. Unit fired up...coughed and sputtered a bit, but runs like a new one. But...generator not generating correct voltage. I got about 46v across L1 & L0.
I also use the 'side boxes' from the MEP 002a...so all electronics are off the MEP 002a. I was thinking I had read that these are interchangeable between 002a & 003a. My next step is to replace convenience outlets in the 'side box'...which is why I just swapped boxes, and use the original 003a 'side boxes. Back to the manual and some deeper digging here.
